Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 06-10-2018, 7:22 PM
llwade's Avatar
Default hearing NXDN
Question on listening to NXDN ( Rail Road ) . Can I listen to a Rail Road frequency, without programing as a NXDN station. If I can, will it sound any different if I program as a NXDN station. note: my 536 has the DMR programmed into the radio. Just haven't used it yet. thank you for your time
73s
LLWade
email: leroywade@mediacombb.net
BCD996XT, HP-1, BCD536HP, SDS100
Old 06-10-2018, 7:55 PM
hiegtx's Avatar
Mentor
If you look at the Railroad systems' in the master database for the 536HP (it's under the Nationwide Systems folder for any state/county), the default audio type is "Search". So, you would hear anything transmitted as analog or digital. Of course, if it really is using NXDN, you would have to have that upgrade to hear clear voice instead of digital noise. As far as I know, railroads are not using DMR, at least in my area. NXDN is not yet in widespread use, only in a few areas, or for some yard operations. As long as you have the NXDN upgrade, and the audio mode is set to 'search', you would hear whatever is transmitted, regardless of whther it's analog (not digital), or NXDN. You don't have to specify NXDN for that to happen.
Steve
SDS100-436HP (2)-536HP-TRX-1-325P2-among others
Old 06-10-2018, 11:02 PM
Depends. If it is bnsf, it might be nxdn. Especially in a yard or intermodal. Mainline tracks, no nxdn programming is needed.
Old 06-10-2018, 11:30 PM
hiegtx's Avatar
Mentor
Yep
So far, only one channel using NXDN in my area. And that is indeed a BNSF intermodal yard near Alliance Airport north of Fort Worth. That is out of range for me in Dallas.
Steve
Old 06-11-2018, 1:50 AM
llwade's Avatar
Gentlemen, thank you for your quick reply..
73s
LLWade
