Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 06-27-2018, 7:23 PM
Default BCD436HP
just purchased Uniden 436hp, preprogramed from seller by county and state is a zip code entry still needed?
Old 06-28-2018, 4:33 AM
If the database and groups have been set up to your liking there is no need to use the zip code feature.
Old 06-28-2018, 5:53 AM
jonwienke's Avatar
Wrong. Unless location control has been disabled in every favorite list, you still need to set your location, or the scanner won't know if the stuff in the favorite list is in range.
Also, paying the seller to program the scanner for you is pretty much a scam. All they are doing is making a second copy of stuff already in the database that you get for free with the scanner. Unless they programmed stuff not in the database, you basically lit that money on fire.
Old 06-28-2018, 12:18 PM
bob550's Avatar
If you ever plan to scan the entire database, which on occasion I do with my 536, entering a zip code is necessary so that you're not scanning agencies you'll never receive. Better yet for improved accuracy, get your exact GPS location and enter that instead. That said, without location scanning activated, you may actually be able to receive transmissions that would normally be skipped because you were outside of the intended transmission range. Of course, that is heavily dependent on the antenna you're using. We have to remember that, not so terribly long ago, scanners didn't rely on GPS programming. You would simply manually program the frequences you thought you could receive based on some guesswork. So provided that what has been pre-programmed into your 436 is within your current reception range, and as Jon says, location scanning is disabled, you should be OK with no zip code.
Uniden BCD536HP, BCD996xt, BC890XLT, RS PRO-651, PRO-163, PRO-2006, PRO-93, Icom R5, R71A, Sony 2010; SDRPlay RSP2, RTL-SDR Blog V3, NooElec NESDR Mini 2+
