Any radio system can be simulcast, not just P25 P2.
Simulcast systems are more expensive, but they use fewer frequencies, the signal footprint can be better controlled to match the intended coverage area, and they work better in urban areas with lots of buildings. So they are fairly common in urban areas, but less so in rural areas.
If you travel a lot with the scanner, I would recommend the SDS100 because it has a database that covers all of North America, can use GPS to automatically select systems and channels from the database to scan, and it is currently the only scanner available that is specifically designed to receive simulcast systems properly. The more you travel, the more likely you are to encounter simulcast systems.
