Thanks for your help. I down loaded my scanner onto Sentinel. Looks like all I need is there but not coming across my scanner. They changed the forum and do not see a red triangle anymore. Thanks. Bear:
In the new forum, use the Report link that you see in the lower left corner of your post. Make your request to have the thread moved to the state forum, if you still wish to do that. (I originally answered your first post in the old system, but the setup had changed by the time you read the answer.)
Another thing that you may want to do, either here in this forum, or after it's moved to the state forum (if you submit the request) is to post your programming file as an attachment.
Attaching an *.hpe file to a post
Use Sentinel to "read from scanner" if you have made changes on the scanner that were not also made in Sentinel.
Then, export the resulting Favorites list(s) into an *.hpe file. Then, attach that to a post and upload so that we can take a peek & see if anything is out of place. The Export function is listed under the File drop-down menu.
If you cannot directly attach an *.hpe file to your post, you can use this workaround:
To upload an *.hpe file, to the Forums, you must change the file extension to one acceptable per forum requirements. To do that, note where your exported *.hpe file is saved on your PC.
Using Windows Explorer, find the file.
There are two ways to do this. You can either change the file extension itself, or compress the file using
7-Zip or other file utility. The *.zip file extension can be attached to a post and uploaded to the Forums.
Or, using Windows Explorer, rename your file one of these two ways:
For illustration, let's call your exported file '
MyFile.hpe' (without the quotes).
<Right><Click> on the file & choose Rename from the pop-up menu.
You can then rename your file to
MyFile.txt, or
MyFile.hpe.txt in order to attach it to a post. Whoever views the file will need to reset the file name back to
MyFile.hpe, then it can be imported into Sentinel for viewing.
