Dec
MB
North East N.Y.
Looks like DEC in Region 5 changed their PLs again. Both the Rangers and Encon Officers use the same frequencies now. 159.225 (various PLs) is used to talk to Central Dispatch and 159.435 (various PLs) is called "Tac" and used for car to car and to talk to the part time dispatch in Raybrook.
So far for both frequencies it looks like they are using:
131.8 - Gore, Blue and Black
173.8 - Whiteface
Are they doing this in the rest of the state? Anyone log any other PLs?
Warthog1
Silent Key
Northville, NY
I just noticed 159.435 is called Tactical yesterday when they were getting rangers together to search for missing 3 year old in Northampton Beach campsite. 3 year old found and is OK.
Campsite operates on 151.250.
Warthog1
Silent Key
Northville, NY
Been monitoring since about 8:30 and so far:
159.435 PL 131.8 Gore
159.225 PL 131.8 Black
159.225 PL 94.8 Cathead
159.435 PL 77.0 Unknown tower
159.435 PL 173.8 Blue Mtn.
Will update as I get more
D
DaveNF2G
Guest
I can't help but wonder where the money is coming from to keep rearranging these big radio systems.
Mtnrider
Greene County New Yawk
Our region uses 159.330....guess i'll have to unlock it from =scanner...and i am with Dave who's paying (well we know who) and why i wonder...and mor interesting wonder if they change the inputs....i know 151.250 NO tones is mostly used for the parks
Mtnrider
Logged 94.8 and 136.5 on 159.330 94.8 used to be Stamford Utsuyantha....But was coming in real weak. 136.5 was real strong and i live where i can hear stamford real well.... suggests that 94.8 has moved...i'll keep a ear out..."update 411 to 413 on Utsuyantha" 136.5 PL ...update 8N418 was just using 94.8 and it was scratchy but he said "On Buck" .............so it looks like
Stamford (Mt Utsuyantha) 136.5
(Buck) 94.8
Warthog1
Silent Key
Northville, NY
Today I have Northampton Beach Campsite portables displaying 218.1 PL instead of 118.8
And now they are 118.8. This is most likely equipment shortcomings on my end. They are only running portables.
I will set up 3 radios to do a PL search and see what happens.
N
Warthog1
Silent Key
Northville, NY
Thanks to the BC996, the portables are actually CSQ as MtnRider already stated. The 996 confirmed it while the cellphone store (Radio Shack) rigs kept stopping on all 118.8 and a few others.
THANKS UNIDEN !!!
D
DaveNF2G
Guest
Getting multiple CTCSS readings on a scanner is a good indication of CSQ.
Also, 136.5 and 131.8 on some scanners indicate reception of DCS codes. DEC uses CTCSS systemwide, but on unknown transmitters, it's good to check DCS also when seeing these tones.
Warthog1
Silent Key
Northville, NY
Well.......thank you Dave. I had one scanner also running DCS search at the same time, but since I realized that DEC uses CTCSS, I didn't feel the need to mention DCS because some scanner wizard would jump all over that and try to correct me. When I do these searches I try to have all of the bases covered.
By the way, how's your list of Saratoga County talkgroups coming along ? I'm up to 31 (which someone would probably try to tell me that I'm not hearing )!! LOL
n2ops
Mount Morris NY
Multiple PL's
If you have enough channels in your scanner enter the frequency with each indicated PL. If your scanner shows counts or if it records per channel you can narrow down who is on which PL. And of course note what you are hearing live on each frequency and PL.
D
DaveNF2G
Guest
My talkgroup list is where it was. I'm still only hearing one weak site.
