I'am having a with my scanner on the 460.3375, Buffalo PD A&B District ch 460.350 splaches in. I only recive dispatch at this time I want to see if Buffalo cars come in on the 460.3375 ch..
Do you know why I here a weard sound on Hamburg PD radio in between transmissions? Allmost sounds like a wisteling!
Do all PD radios hear the noise my scanner has the DPL code and I still hear it!!!
It seems that a another agency is using the same freq. but when that comes in it seems to be encoded.
It seems to occur more during the week. I am listening today on a Sunday and it works perfectly fine. I which there was a way to listen only to Hamburg Police and block out the other agency.
If I use my veh scanner Buffalo Pd B Dist. will be picked up 460.350. I still hear the whistling between the transmissions! It sound like a whisiling i belive it may be the repeter I've been around radios for 30 years.
I get that noise also. It sounds like a bleedover or something. that Buffalo PD frequency is very close. You would think that these agencies (or the fcc) would predict interference with such close frequencies (is that is the isuue). I tried using att on my bct15 but i'm too far from Hamburg.
So far I don't see a fix Buffalo's radio system has many reapeters! You need a scanner that can be programed with tone codes. A few years ago Buffalo had to change tone codes, because the Sharref's Dept. splashed over.
