Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum - Forum for discussing Radio Information in the State of New York.
  #81 (permalink)
Old 09-14-2017, 6:24 PM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
Originally Posted by studgeman View Post
It will be a phase 1 control channel. You will almost never see a phase 2 control channel (not sure standard is complete) because it breaks interoperability.
Control channels are the same whether it's a Phase I or Phase II system.
Mike.
  #82 (permalink)
Old 09-14-2017, 6:42 PM
Thumbs up Oneida County Radio Technicians Talk Groups
1 (1) 005 (5) Oneida Simulcast Oneida
Also 154.250 is active
DEC : 65000 Radio Technicians
DEC : 65001 Radio Technicians
DEC : 65002 Radio Technicians
DEC : 65003 Radio Technicians
Unit ID : 991741 Radio Technicians
Unit ID : 991744 Radio Technicians
Unit ID : 300012 Radio Technicians
Unit ID : 6500011 Radio Technicians
  #83 (permalink)
Old 09-14-2017, 6:50 PM
FWIW: There is provision in the standard for a phase II control channel. I don't believe it is finished, and I have never seen it implemented. It has been a low priority for TIA. For practical purposes it doesn't exist, yet.
  #84 (permalink)
Old 09-14-2017, 7:34 PM
GTR8000's Avatar
Troublemaker
It doesn't exist yet, period.
In February, the TIA 'approved for ballot' a proposed standard for a TDMA control channel, however it is still very much a work in progress. No current TIA Project 25 standard includes any provision for a TDMA control channel, thus it only exists on paper at this point.
  #85 (permalink)
Old 09-18-2017, 11:59 AM
Thumbs up TESTING P25 Phase II fixed-end 2-slot TDMA
BCD436HP
Radio Technicians are testing P25 Phase II fixed-end 2-slot TDMA Talk Groups
PT0 = channel is receiving Phase II time slot 0
PT1 = channel is receiving Phase II time slot 1
65000 fde8 T Radio Techs Radio Technicians PT0 Phase II
65001 fde9 T Radio Techs Radio Technicians PT1 Phase II
  #86 (permalink)
Old 09-18-2017, 4:12 PM
Smile radio range testing P25 Phase II fixed-end 2-slot TDMA
radio range testing
1 (1) 005 (5) Oneida Simulcast 151.010c 151.370a P25 Phase II fixed-end 2-slot TDMA
  #87 (permalink)
Old 09-18-2017, 5:41 PM
GTR8000's Avatar
Troublemaker
FYI: talkgroups are not assigned to TDMA time slots on Phase II trunked systems; they use whatever repeater and slot is available. Fixed time slots is a DMR thing, not a P25 thing.
  #88 (permalink)
Old 09-19-2017, 7:53 AM
I listened to the Radio Techs (talkgroup 65000) chatting last night via my BCD536HP. The audio was crap and I suspect this is my scanner. Is anyone else hearing it any better than I am and what are your settings? If they talked long enough, I might try to adjust the P25 threshold option. Any thoughts on tweaking this setting from Auto to Manual and then selecting a value?
Amateur Radio Extra Class
HackRF One, Icom IC-706MKIIG, Kenwood TS-590SG, Realistic PRO-2006, (3) RTL-SDR (RTL2832U), SDRPlay RSP, Uniden BCD536HP
  #89 (permalink)
Old 09-19-2017, 9:00 AM
I put these 2 frequencies in my scanner . It kept stopping on both,showing a fairly high signal strength, but just noise. I took off the antenna off and it goes away. This was last night so wouldn't have been the techs.
  #90 (permalink)
Old 09-19-2017, 9:44 AM
What is your location? I have an bcd436HP and the audio is great. Did you update your firmware for your BCD536HP. That will fix your audio.
The talk groups for range testing are:
talkgroup 65000
talkgroup 65001
  #91 (permalink)
Old 09-19-2017, 9:48 AM
Default Range Testing In Utica
There range testing towers on HIGBY ROAD and BURRSTONE RD. in Utica.
  #92 (permalink)
Old 09-19-2017, 1:18 PM
I did hear a quick blurb of a voice today . That's it. I'm a ways off the just North of Rome. I was just on the rubber duck antenna so that sounds about right.
  #93 (permalink)
Old 09-19-2017, 1:42 PM
talkgroup 65000
talkgroup 65001
I am up in Camden using an outside antenna (Discone) fed with LMR-400 coax. I manually added the frequencies to a favorites list prior to the updates of RadioReference. So I wonder if I created my own issue? Maybe I will delete my additions and use the information from the RadioReference database to see if there is a difference.
I am quite positive my firmware is updated, but will check when I get home.
  #94 (permalink)
Old 09-19-2017, 1:50 PM
Can you hear the control channel on 151.010? The South Charles Street site in Rome is transmitting because I can see the signal meter on my Icom 706 and it is strongest on Erie Boulevard.
  #95 (permalink)
Old 09-19-2017, 2:08 PM
MegaHertz315's Avatar
Listening on a Relm KNG. Coming in great from central Oswego County
Len
Central/ Upstate New York
  #96 (permalink)
Old 09-19-2017, 2:09 PM
I'm getting 4 to 5 signal bars ,squelch off ,white noise. On 151.01 5 bars, no sound at all.
  #97 (permalink)
Old 09-19-2017, 3:01 PM
Smile Range Testing Rome Towers
use the information from the RadioReference database.
They are range testing these towers below..
BASE RD NEAR JUDD RD
ORISKANY, NY ONEIDA County
216 S. CHARLES ST.
ROME, NY ONEIDA County ..
  #98 (permalink)
Old 09-21-2017, 1:24 PM
A lot testing radios yesterday on Fire Control 154.37. Testing alot of radios with sequential numbers.
  #99 (permalink)
Old 09-22-2017, 12:41 PM
They must have switched over to the simulcast
  #100 (permalink)
Old 09-24-2017, 9:03 AM
Thumbs up Engineering REVIEW FOR WQYF524
http://wireless2.fcc.gov/UlsApp/Appl...plID=10533366#
https://wireless2.fcc.gov/UlsEntry/a...Ind=applAttach
