800Mhz & 700Mhz?
C138NC
Tactical Taco Consumer
NC Taco Command
So 700Mhz is reserved for emergency responders, so will 800mhz be obsolete for everyone including law enforcement?
Something i was hearing in a class, plus is it true 700mhz can penetrate through concrete or something? I might not even be making any sense with my question.
Newshound
Aurora, IL
The FCC opened up the 700mhz band for law enforcement after they mandated the interoperability between agencies by 2013. That was a reaction to the 9/11 attacks. Some agencies are going to the 700mhz band while others are being rebanded to other frequencies on the 800mhz band. Many of the rebanded 800mhz will convert to digital, which allows more channels on less bandwidth. 800mhz will not go away, but the government is freeing up some more of the 800mhz band for other non-law enforcement uses.
700mhz band works the same way as 800mhz. Since the frequencies are slightly lower on the bandwidth, they may travel a short distance further, but the same problems will exist within buildings. The lower you are on the bandwidth, the further the signal will travel with the same amount of power, but the difference between 700mhz and 800mhz would not be significant.
KM4WLV
Rockwell (Rowan County), NC
Also as far as building penetration any big buildings such as a sky scraper (office type building), large hotels, and any other building that radios may have a hard time TX & RX, are required to have an inbuilding repeater and antennas so communications are ensured while inside.
C138NC
NC Taco Command
Ok so really, 800mhz will still be around for us to use? "Emergency Resp" and I guess law enforcement? I dont know if its just true if 800mhz will become obsolete unless theyre keeping it, cost too much just to make a change but if were going with digital cable, why cant we utilize digital VHF/UHF like the Virginia STARS system? or is there a higher cost to it then its 800Mhz counterpart?
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
... why cant we utilize digital VHF/UHF like the Virginia STARS system? or is there a higher cost to it then its 800Mhz counterpart?
There is nothing to prevent an agency from constructing a P25 trunking system on VHF or UHF, rather than 700 or 800 MHz. Wayne County is a good example for VHF trunking, and they have two circumstances going for them that should help the implementation: they were already licensed / coordinated for some of the system frequencies, and they are using the same frequencies at each site.
As the coverage area of a potential VHF or UHF trunking system grows, so do the problems of coordinating frequencies with other users in the region who are already on the same or adjacent frequencies. And the normal propagation characteristics of VHF and UHF, when compared to 700 and 800 MHz., add to the headaches.
The people involved in the planning and implementation of the STARS system had the good fortune of applying for VHF frequencies at a time when VHF splinter channels were still relatively unlicensed. They are now also licensed for numerous frequencies in the 152.5 - 152.8 MHz segment, which was originally available to commercial mobile phone services in the pre-cellular phone days.
I can only think of two other states that have deployed VHF trunking on a statewide level - Alaska and South Dakota.
With regards to 700 and 800 MHz., there is no reason to make 800 MHz. "obsolete" ... unless the F.C.C. decides to auction off more spectrum. The 700 MHz. spectrum is intended to enhance interoperability, and each "region" will have a coordinated plan on file with the APCO regarding how agencies within its boundaries will use the 700 MHz. allocations within the spectrum. A similar plan exists for 800 MHz.
(A "region" consists of a state or U.S. territory, a group of states, or a portion of a state that coordinates use of a portion of radio spectrum within its boundaries. North Carolina is Region 31. The chairman of the Region 31 700 MHz. planning committee is a subscriber and occasional poster on the N.C. Forum on RR, btw.)
Although some hobbyists think of 700 MHz. as a separate entity from 800 MHz., frequencies from both bands can be used at the same trunked site when compatible transmitting and receiving equipment is in place.
For instance, Lake County, Fl. operates a multi-site P25 system with 700 and 800 voice channels being allocated by an 800 MHz. control channel.
