Dobson Knob Fire
drayd48
I am going to try to check this fire out tomorrow. Are they just using McDowell County tac channels that would normally be used? If so what are they? What about statewide events channels on VIPER? Does anyone know any forestry frequencies? Thanks
kc4wsd
Rockingham County, NC
This isn't exactly what you were asking for, but it might be worth plugging in and monitoring . . .
The FAA has issued a Temporary Flight Restriction (TFR) over the area of the fire, and the contact agency is listed as the NC Forestry Service on 123.125 MHz. You MIGHT be able to catch some activity on that frequency.
David C.
Sent from my SM-N920V using Tapatalk
drayd48
David C.
Ok. Thanks. Anything I can get. I will look for the TFR to find out where the fire exactly is.
WNC
NCFS 151.475, 151.445, 159.300
USFS 168.725, 169.900
122.925
Not much relating to the fire on local frequencies, at least not anything that I can hear from the central part of the county
Structure protection units may be using State Fire 154.280
Other local TAC frequencies are: 153.950, 154.220, 154.325, 154.400 and 155.580 (North Cove Repeater)
Don't know about VIPER
During previous fires some of the comms guys have come up on the local ham repeater 146.985
ecps92
Taxachusetts
151.4750 R - NCFS - Gibbs Peak Rptr
151.4000 S - NCFS - 1
151.4600 S - NCFS - 2
151.3100 S - NCFS - 3
151.2650 S - NCFS - 4
1-4 are for Tactical use, based on which Branch of the Fire
151,2800 S - NCFS - 5
5 is for Logistics
171.5750 S - Air/Ground - 8
NC Air/Ground Ops
154.2800 S - NCFS - 12
12 is Structure Protection & Overnight Ops
168.6250 S - Air/Guard
Also, VIPER "Bravo 3" is in use.
