Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of North Carolina.
  #121 (permalink)
Old 06-18-2018, 9:43 PM
troymail's Avatar
Silent Key
VIPER Brunswick Law 3/West
Unication G5(UHF)
  #122 (permalink)
Old 06-20-2018, 10:15 AM
Ok trying to figure Robeson Co Out Sheriff now dispatching on Tg # 39550 not in DB
  #123 (permalink)
Old 06-20-2018, 11:38 AM
Robeson Co has come up on several Talk Groups not to be heard again I will try to figure out what is going on with this
  #124 (permalink)
Old 06-20-2018, 11:49 AM
Location: New York North Carolina and all points in between
Quote"
When we get heavy rain, I even watch my G5 lose signal of times ("Out Of Range") only to return a short time later when the sun returns
Properties of higher frequencies, even worse for microwave systems. Since the TV change to digital and the use higher frequencies I lose some stations based on weather, rain or fog.
Will be in the Southport area in a few weeks for R&R, and I have never have problems with drop outs, but again I am using XTS and XTL radios.
  #125 (permalink)
Old 06-30-2018, 12:48 PM
I am putting together a few systems for NCSHP and other agencies on VIPER and I am only adding sites in the 2 or 3 counties I travel daily but I still want to limit the number of freqs scanned as to not miss much.
RR lists them all of them per site and highlights the primary and secondary freqs. Should I only add those to each site, or add them all?
J
Nothing clears the mind like a lack of alternatives!
  #126 (permalink)
Old 06-30-2018, 2:59 PM
troymail's Avatar
Silent Key
J
You can probably get away with only programming the primary (RED) and alternate (BLUE) frequencies for each site.
However, for the most part, programming all of each site's frequencies won't negatively impact scanning as long a you have a good signal and reception. Once the radio finds the proper control channel frequency, it really doesn't care about the others (unless the signal quality drops).
Unication G5(UHF)
  #127 (permalink)
Old 06-30-2018, 3:14 PM
MedicDavid78's Avatar
Question VIPER Counties
I was wondering something. For all the Counties listed under the VIPER system page, would it be fair to say if the Counties don't have TAC 1-8 or multiple TAC channels that means they aren't using the system primarily yet? I've noticed the counties that do use VIPER have a good amount of talkgroups including a few TAC channels. And some of the Counties that I know don't use it yet only have a few basic talkgroups like Fire, EMS, Sheriff, EM, TAC, & Mutual Aid. That seems to be the basic channels offered until primary use. Would this assumption of mine be accurate? I was mainly wondering because I was trying to find out if Alexander County was using the system yet or still using their VHF/UHF channels, and I can't find any info searching the forums here. Thanks in advance!
David
Ham: WN4EMT, GMRS: WRAX515
Radios: XTS5000, XTL5000, XTS2500, HT1250, Baofeng UV-82, Anytone D868, CS-800D
Scanners: Uniden BCD536HP, Uniden BC246T
  #128 (permalink)
Old 06-30-2018, 3:21 PM
troymail's Avatar
Silent Key
You can't really make assumptions. Some counties have their own systems... some counties are very small and don't need alot of talkgroups. In some cases, it could just be that all of a counties talkgroups aren't listed (yet) or maybe they are encrypted so we don't know which is which... lots of possibilities...
Unication G5(UHF)
  #129 (permalink)
Old 06-30-2018, 3:23 PM
For departments that are still on their conventional channels you sometimes can find the primary dispatch channel being simulcast on their VIPER talkgroup. Bertie and Craven counties are this way.
  #130 (permalink)
Old 06-30-2018, 3:37 PM
northampton does this with ems also
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
  #131 (permalink)
Old 06-30-2018, 3:55 PM
Wouldn't it be nice if there were one or two folks in each county who were the "expert," so to speak, and the "go-to" person for scanning knowledge?
Sent from my Note 8 using Tapatalk
  #132 (permalink)
Old 06-30-2018, 4:17 PM
It'd also be nice if people from the counties with limited or new Viper radios would add them to the Viper Radio ID Wiki page, so we can track where transmissions are coming from.
North Carolina VIPER P25 Radio ID's - The RadioReference Wiki
Whistler TRX-1, Radio Shack Pro-668 (mod), Pro-197, Pro-651, Pro-106, Pro-96
Baofeng 888, UV82, UVB5, Connect Systems CS750
  #133 (permalink)
Old 06-30-2018, 4:29 PM
Agree. While I'm guilty of not keeping an eye on the Wiki pages, I'll make that my Mid Year Resolution . . .
The VIPER radios seem to be in pretty good shape for my county, but I'll try to build the general county page because it seems a little slim. Thanks for the nudge.
  #134 (permalink)
Old 07-05-2018, 1:02 PM
newsnick175's Avatar
Lincoln County Sheriffs have now lit their VIPER TG (28004) with simulcast of their UHF. There is about a 1/2 second delay and all units appear on the same UID: 1090088.
That goes along with the Fire dispatch simulcasting on 1090000.
The “com center” has been heard on TGs 1090001 and 1090002.
Denver’s Engine1 has the only “unit ID”: 1090136 so far.
Be a good citizen, stay informed, prevent Truth Decay!
  #135 (permalink)
Old 07-05-2018, 2:14 PM
Thanks for the information, I went ahead and updated the Wiki page with the RID/UID information.
  #136 (permalink)
Old 07-06-2018, 5:22 PM
Default Is Rowan County Simulcast on Viper?
Heard Rowan county assisting with funeral escort on Viper Foxtrot 2 today, all units had RID of 1591895, just wondering if anyone can tell me if they are simulcast on Viper or if they have there own viper radios with individual RIDs? The Viper RID Wiki doesn't have any Rowan info.
  #137 (permalink)
Old 07-06-2018, 5:27 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Many Counties were assisting with that escort including Durham. I can say that Durham was using individual RIDs along with Wake agencies that helped as well.
Marshall KE4ZNR
Sent from my Pixel XL using Tapatalk
NC/SC Forum Moderator/Database Administrator
All opinions are exclusively those of the author
and in no way reflect the position of his employer,
contractors or other parties.
  #138 (permalink)
Old 07-07-2018, 6:58 PM
Caught TG#52279 Lumber River State Park this is the first state park viper Tg that I have hear active
  #139 (permalink)
Old 07-13-2018, 6:00 PM
Metrofire31's Avatar
Default Macon County EMS
Macon County has shifted primary EMS dispatch to VIPER TG 29001, effective this week. The UID for Dispatch is 1130013. EMS units have been using VIPER for all patient reports to hospitals throughout Western NC for some time. My understanding is that Macon County intends to shift ALL emergency dispatching traffic to VIPER but fire units will be converted at a future date.
Metrofire31
Franklin, NC
Metrofire31
Franklin, NC
WQIT636 (GMRS)
996P2/996XT/780/796/296D/396T/396XT/436/XTS2500/XTS5000/NX300/CS701
  #140 (permalink)
Old 07-15-2018, 8:24 PM
Somebody had a typo!
YE WQRB855
NORTH CAROLINA STATE HIGHWAY PATROL
[LAW ENFORCEMENT ACTIVITIES USING STATEWIDE TRUNKED SYSTEM]
Control Point 1 - 3318 GARNER ROAD, BLDG #2, RALEIGH NC 888-928-4737
(link)
07/13/2018 License Modified
(transaction log)
1 - HP-1345, ASHEBORO DT, HP-1345, ASHEBORO DOT, 957 SOUTHMOUNT DR., ASHEBORO (RANDOLPH) NC [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 140.2m, Polarization: Vertical, Gain: 10.0dBi, HAAT: 198.3m]
856.1875 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
856.5375 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
851.1375 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
851.3125 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
851.95 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
852.425 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
852.9125 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
853.5125 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
853.8125 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
855.2375 FB2C Ant: 1 100p 110e Units: 1 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
2 - 45.0 km radius around fixed location 1
811.1875 MO Ant: 1 35p 35e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
811.5375 MO Ant: 1 35p 35e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
3 - 40.0 km radius around fixed location 1
806.1375 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
806.3125 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
806.95 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
807.425 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
807.9125 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
808.5125 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
808.8125 MO Ant: 1 35p 40e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
810.2375 MO Ant: 1 35p 35e Units: 1250 8K30F1E (NXDN) 9K80D7W (P25 Phase II)
Purveyor of Broke Busted or Bedlam, INC!
K4NWJ
Tags
durham trunk frequencies, nchsp, sticky
