Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of North Carolina.
Old 04-27-2018, 7:24 AM
troymail's Avatar
Default Wake County system...need input
I probably should have asked sooner but....
I've always been curious about the two sites of the Wake County system given they apparently both used the exact same frequencies.... I'd really like to better understand how this works....
Anyway, I'm driving up through the area later today (and back in a few days) and am interested in knowing if someone in the area can confirm a couple of things:
1. Are the primary control channel frequencies for the two sites accurate as posted in the RRDB (Simulcast site>853.7875 and FV>853.925)?
2. Are these stable in that I shouldn't expect them to change (often if at all)?
I'm trying to program radios such that I ensure I am monitoring both sites as I pass through vs. the radios locking onto the same control channel frequency for both sites (as expect it will do unless I "tweak" the programming).
Thanks!
EDIT: I should have included this reference earlier - but better late than never...
https://forums.radioreference.com/no...stem-rrdb.html
Unication G5(UHF)
Old 04-27-2018, 3:05 PM
Sorry for the late reply, short answer is YES and YES
Whistler TRX-1, Radio Shack Pro-668 (mod), Pro-197, Pro-651, Pro-106, Pro-96
Baofeng 888, UV82, UVB5, Connect Systems CS750
Old 04-27-2018, 6:15 PM
troymail's Avatar
Definitely see a different CC frequency for each site (as is posted).
Curious to see if there is frequency reuse .... will look more closely once I return home.
Unication G5(UHF)
