dancrosoft
Can anyone tell me the best place to buy a G5? I am tired of the distortion on my TRX1 when monitoring the USAI system.
Ready to pull the trigger and have clean audio
2nd that on RAY'S. I got my G5-v Pager there as well as the Charger/Amp. Great service and prices. GOOD for YOU that you are putting the Whistler on the bench. I had to do the same with my WS1080. I was shocked to hear my 2004 Pro96 doing far better than the WS1080 when it came to P25 Simulcast reception and digital 400mhz reception. The G4/G5s are fantastic. The scanners don't compare. Right tool for the right job.
That's why I got the Vhf version. I like to have one Zone for Scanning NOAA Weather freqs wherever I might be in a free-scan setting. Also have Conventional Zones for those analog freqs still around me. Not sure which the internal antenna is best on? VHF or UHF? there is no outside antenna for those. The little antenna is only for 700/800mhz. Even with that? I still get VHF 155.000 from a county away and works great when there are analog freqs in town. Just depends what is most important to your area that you want to listen to besides P25 digital
Can anyone advise what is the maxish number of TGs I should program in this thing? I think I recall reading a thread where a guy put in a TON and it slowed the device down horribly.
I haven't noticed the number of talkgroups slowing the device down. What I have noticed is that the more talkgroups and systems I have in the radio, there can be an issue with the signal dropping following a transmission. In my experience I've noticed this occurring only on patched talkgroups. The Phase 2 upgrade firmware seems to have greatly reduced this issue. It didn't eliminate it but it's much better than before.
I did create a small code plug with just my local CMPD division, and a couple other talkgroups. With that code plug I don't have any signal drop at all, so it appears it could be related to the number of talkgroups and systems in the radio. The typical code plug I have in the radio has around 500 talkgroups, and multiple systems (UASI multiple sites, VIPER, and SC Palm 800).
Just create what you want, see how it goes, and tweak from there.
