Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of North Carolina.
  #41 (permalink)
Old 06-29-2018, 1:34 PM
jonwienke's Avatar
New release firmware is out for the SDS100.
  #42 (permalink)
Old 07-02-2018, 9:40 AM
troymail's Avatar
Moved the radio to a spot on my desk where reception for the NC VIPER sites was improved - still only seeing about -105 dBm.... Then, decided to plug it in before the battery dies.... immediately get the LOW USB BUS VOLTAGE error ... I just can't seem to win with this thing.
Switched from a hub to a direct laptop port (same cable) - so far, so good on power but since "touching" the radio (while trying to maintain position), reception dropped off again.... even back onto battery power.... very finicky.
EDIT: after listening a bit on battery, I carefully plugged in the USB cable (without moving the radio) - lost reception again. Noise values in the 5 digits range... remove the USB cable from the radio - noise values in 3 digit and reception returns.
Unication G5(UHF)
  #43 (permalink)
Old 07-02-2018, 10:21 AM
chief21's Avatar
sounds like you've got a noisy USB power source
  #44 (permalink)
Old 07-02-2018, 10:26 AM
KevinC's Avatar
Moderator
Your "hub" probably can't supply the necessary current and I agree on the noisy power source.
Someone told me signatures are silly, so I got rid of mine.
  #45 (permalink)
Old 07-02-2018, 10:33 AM
jonwienke's Avatar
Your USB hub and laptop can't handle the current required, and are generating enough RFI to make you lose signal. RFI increases when you overload a switching power supply.
Try an AC extension cord, and the factory USB adapter and cable.
  #46 (permalink)
Old 07-03-2018, 7:53 AM
troymail's Avatar
Doing some testing with the SDS-100 connected to the same outdoor antenna my 536 is usually connected to ...
The 536 - using that same antenna - does pretty well receiving VIPER.....
The SDS-100 - not so much... seeing lots of initially clipped transmissions and at times, hearing transmissions on other radios, the SDS is silent (occasionally showing it stopped on the talkgroup but with no audio - even during longer transmissions).
Unication G5(UHF)
