Good afternoon all, I am currently running the Buncombe County System as a Phase 2, with the I.D. search on. All of the I.D.'s that appear are identical to the I.D.'s assigned as a Phase 1 system..... I will let you all form your own opinions as to the meaning of that. I know what I have been told in the past, I understand that, and agree with it. I can simply tell you the I.D. numbers are in the same format as they have always been.... Take care, have a great day.
I have never had the chance to monitor a true Phase 2 system that migrated from Phase 1. But, I have been told the I.D. format will be distinctly different than the original Phase 1 system...
Interesting,,, that does make sense. I had been thinking when referring to format, that say an I.D. was 4034 for Buncombe Fire Med, it would switch to 400062 or something. But I see what you are saying. I was confusing when Asheville P.D. went from M-36 to P25, and that changed everything. I can see clearly now, the rain has gone....
That is incorrect. All P25 (Phase 1 or Phase 2) is digital.To those with P25 phase 2 experience: It is my understanding that phase 1 is analog and phase 2 is TDMA digital.
I believe the control channel is more or less the same for both Phase 1 and Phase 2 - just some different data given the bandplan/channel handling is different.My Unitrunker receiver is just a standard SDR dongle. If any local system goes 100% phase 2, would I still be able to decode the control channel (only) with the SDR dongle? I realize that I would need a phase 2 receiver to monitor any voice traffic, assuming no encryption.
nated1992,, if you can, can you build and monitor both the Phase 1 and Phase 2 systems?? Then see if the voice modulation is distinctly clearer on the Phase 2 system. Could simply be my goofy imagination, but I have been switching back and forth between the two, and Phase 2 sounds much clearer to me....
Motoman55, I had thought you were located in the east of the state, I just looked at your original post, are you close? If your able to, can you compare the two. It would be interesting to see if someone else detects a difference.
