The 49 MHz walkie talkies used:
49.830
49.845
49.860
49.875
49.890
I have a pair of 5 channel TRC-512 radios from Radio Shack. They've been discontinued for years, though. (The 2nd radio I bought was the last one in all of Arizona.)
I've never heard any two-way use on those channels. Just the occasional baby/room monitor as I drove down the road. (I programmed 2 banks of my PRO-43 scanner with 49 MHz/MURS/FRS/GMRS and the Amateur 6M-33cm AM and FM calling frequencies, and I monitor them when on road trips.) I suppose there *could* be the odd handset side of a cordless telephone conversation to be heard out there, as well as a fast food drive through to be heard. (I think it was McD's that paired 154.570 with a 49 MHz frequency many years ago for their drive throughs. You could hear both the customer and the clerk on one of the frequencies, but only the clerk on the other, and I don't recall which frequency was which.) But, I wouldn't expect much more than the occasional baby/room monitor nowadays. Surprisingly, the monitors can be good for several hundred yards radius of the transmitter, as I have found out while traveling I-10 near some home developements that back up to the freeway in Buckeye, west of Phoenix.
Here's a page that has a couple of frequency lists for the old cordless phone sets that used 45-50MHz. Included is the even older sets that used 49 MHz for the base, and 1695-1735 kHz (yes, kHz, between the AM broadcast and the 160m Ham band) for the handsets.
49MHz Experimental Radio Club
It should be noted that deliberate monitoring of cordless phones and room monitors is illegal, and yes, I do hit the scan button when my scanner stops on an active channel used by one. Listening to two-way use of the channel is not illegal, so make sure that's what you're hearing!
John
Peoria, AZ
