I need help and might be in the wrong area. I'm trying to run a broadband-hamnet node (wrt54g) and a mesh node (bullet m5) (bridged together) that are both POE powered. The problem is I need to split that one rj45 to power both and can not figure out how. Its going to be about 50ft above the ground (part of the reason for the mesh node is so I don't have to get up there to talk to the hamnet node.) I'm doing this as I don't want to run 200ft of cable across my yard. The wrt54g has a 4 port switch (I don't know if you can convert more than one of the ethernet jacks to poe) and the bullet only has one for combined power/data. The only way I can think to do this would be to series poe injectors but I'd prefer to do this with one wire if possible. Any ideas how to do this?
