KE7IZL
I remember that with NTSC (analog) TV, you could sometimes pull in a weak station (like one from a city 50 miles away) if you played with your antenna, and got it positioned just right. How good is ATSC (digital) TV with this kind of thing? On one hand it seems like it might be better than analog, because with error-correction coding it can correct for errors introduced by the signal being "buried in the noise", making for a perfectly clean picture for a digital transmission, even if it would be noisy in an analog transmission. However, on the other hand, if there are too many errors, and the error correction can't fix them, it will then fail the CRC check, and the packet with the errors will get rejected entirely, unlike with analog where SOMETHING (however degraded it may be) is shown on the screen, no matter how weak the signal. So in the end, does ATSC work better or worse than NTSC for trying to see distant/weak stations? Anybody have any experience with this?
