Does New Philidelphia Fire Not Have It's Own Channel Like THe Police Do.
I Have The System In My Radio Now. Also as far as status bit and end code do you ignore them or do you have them enabled
Leave End Code at whatever the default is. As far as status bit, I can't answer. I forget on Unidens if you _have_ to have status bit on to hear emergencies, patches, etc or if you only need to turn it on to _recognize_ that its an emergency, patch, etc.
If you don't know about status bits, there are certain bits that are on if it's a patch, if its encrypted, if its an emergency transmission, etc.... and with status bit off the normal TGID would show up. With the status bit on the talkgroup that would display would be the normal TGID+status bit.
You'd be fine not touching any of those I'm pretty sure. Maybe somebody else will give you a specific answer.
