Please consider providing a Scanner Feed if your County is not covered by the Ohio Scanamerica Feeds. It is very simple and takes no resources or bandwidth.
I have multiple analog only scanners available to individuals who want to a host a feed in any uncovered areas within Ohio. Contact me if you need an extra scanner that will be used for a ScanAmerica feed.
If you agree to provide a feed they will send you a file which will set up Icecast on your computer with the necessary settings to connect with their server.
