How much can I expect to hear radio traffic wise from one site (422 Newport)? I have recieved very little Post 84 traffic. This is a 3-4 bar recieve site for me as I am within air mile of the tower. I checking to see what I should be able to hear from this site so I can determine if I have the right parameters programmed. Programmed and used scanners for over thirty years but this one a curve ball right between the eyes. Working with a 996t here.
Monk8500
Listening to a single site on Ohio MARCS typically will not provide adequate coverage for OSP, especially in rural areas where OSP units are likely to be spread out pretty far and affiliated with different towers.
If I read what you said correctly, you are within 1 air mile of the Newport site? If so, I would expect more than 3-4 bars of signal. If you are using the stock scanner antenna, the first thing I would do is invest in a Radio Shack 800 Mhz antenna. they are fairly cheap and outperform any stock scanner antenna on 800 Mhz.
I would recommend that you monitor all of the following sites:
* 427 MARIETTA
* 422 NEWPORT
* 426 GLASS
* 425 LOWER SALEM
Obviously, if some are too far away to hear their CCs, then you can't monitor them - but with 2 control channels programmed in per site it's not much of a pain to program in all four.
Since you live in a rural area (like I do) and thus usually would hear less traffic on MARCS to begin with, I would turn on ID SEARCH. This would allow you to hear any activity on any talkgroup that is active on the towers you are monitoring. If you run in ID SCAN mode you would need to program in every talkgroup you want to hear. Of course, that is your choice. And if I were you I would turn on ICALL for the system. That way, if there are any radio-to-radio "private" comms happening in your area, you would hear them too.
There is some good news though. Since OSP has moved to the consolidated dispatching, you may hear OSP traffic from Washington and surrounding counties as long as you program in the appropriate talkgroups.
With the consolidated dispatching, Marietta is dispatched out of Post 7 St. Clairsville. So are Steubenville and St. Clairsville. So, you would want to program in the POST7, POST41 and POST84 talkgroups. Why? Because sometimes you'll hear Marietta traffic on POST84 and sometimes you will hear them on POST41 and sometimes on POST7. The same goes for me up in Jefferson Co - I am hearing our local Post 41 units tlaking to dispatch on POST84 right at this moment, apparently because they are all being dispatched out of the same place and that is the chosen dispatch talkgroup for the evening?
So:
1. Make sure you can receive everything you can
- if you are using a stock antenna, get an RS 800 Mhz antenna - you won't be sorry
2. Make sure you turn on ICALL if you want to hear any private comms
3. Turn on ID SEARCH if you want to hear any MARCS traffic from the local towers (not just OSP)
4. If you elect not to turn on ID SEARCH, make sure you program in POST84, POST41, and POST7 talkgroups as well as P84TAC talkgroup to ensure that you are going to hear the activity of the OSP units in your area.
Keep in mind that in order for you to hear any OSP traffic, at least one mobile must be associated with a tower you are monitoring and affiliated with a talkgroup that you have programmed in your scanner.
PS: I'm up in Jefferson Co and have heard quite a bit of POST84 traffic on our towers up here - you should be hearing them down there. One reason you may not is if there are no OSP units affiliated with the Newport tower.
