K8JSM
I noticed that the REACT channels used in Coshocton are not in the DB. I am on this REACT team, and would like to supply these frequencies for use!
--REACT Ch. 1 - 462.65 (GMRS Channel 19)
-Used for simplex car-to-car while on-scene.
--REACT Ch. 2 - 467.65 (FRS Channel 12*)
-Used for dispatching from the CCSO, and repeats back to Ch. 1. (If you're far away from another member, and they can't hear you simplex, you use Ch. 2 so that it gets boosted from the repeater, which is located at the Sheriff's Office.)
Sean, K8JSM, RE-53
*What's strange about Channel 2 is that it does not actually fit into the FRS frequency chart. FRS channel 11 is 467.6375 and FRS channel 12 is 467.6625. So, we use a somewhat private frequency that is between these, as to avoid unwanted interference, I would assume. Thought it was interesting and worth noting.
Sean, K8JSM, RE-53
