Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #501 (permalink)
Old 12-31-2013, 2:16 PM
jdolina's Avatar
I should have used unitrunker to begin with. I will have to play with re-banding in trunk88
CC 853.97500
AC 853.31250
852.81250
852.36250
  #502 (permalink)
Old 12-31-2013, 2:47 PM
mtindor's Avatar
OH/WV DB Admin
CC 853.97500
AC 853.31250
852.81250
852.36250
Thanks man. I've updated the Grafton site in the DB. Nice job!
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
  #503 (permalink)
Old 12-31-2013, 2:49 PM
mtindor's Avatar
OH/WV DB Admin
CC 853.97500
AC 853.31250
852.81250
852.36250
John,
In trunk88, while monitoring a site in 6F0F, hit ESC a couple of times, then press Z, then use the up/down arrow keys to find the Grafton site, and then in the field called "Base" enter in 802 and hit enter.
Then that site will be designated as rebanded.
Just like UT, you may need to remove any 86x freqs that showed up and let it repopulate.
Mike / AA8IA
  #504 (permalink)
Old 12-31-2013, 3:00 PM
jdolina's Avatar
Thanks for the info....
  #505 (permalink)
Old 01-08-2014, 5:24 PM
Default HomePatrol Problem After Updating The Database (MARCS Ohio System)
Before updating the database for a HomeParol unit I received the rebanded MARCS system just fine. I'm located in Cuyahoga County. Now that I've updated the database today to the HomePatrol I cannot no longer receive the MARCS system. I still receive the MARCS rebanded system on my BCD996XT just fine. I also switched the antenna from the BCD996XT to the HomePatrol thinking this was the problem but still no reception. Could there possibly be a problem with the rebanded custom plan info in the database or is it something I am doing wrong? Thank you for your help.
  #506 (permalink)
Old 02-27-2014, 6:48 AM
wa8pyr's Avatar
Technischer Guru
Default Database cleanup for rebanding
All,
Upon checking the database while updating the Conneaut site (which has now been confirmed as rebanded), I noted that the following sites have not been confirmed as rebanded:
Athens
Carmel Church
Gallipolis
Oak Hill
Now, I'm 100% certain that these sites have been rebanded, but if someone could confirm just to make sure it would be helpful.
Thanks,
Tom
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
