Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #161 (permalink)
Old 09-01-2013, 5:13 PM
Bucko's Avatar
Clarington Tower CC 851.9375 6F10H-0034. I have not heard much traffic but then this has been low traffic in the past.
  #162 (permalink)
Old 09-01-2013, 5:27 PM
mtindor's Avatar
OH/WV DB Admin
Thanks man. Appreciate it. The DB has been updated.
Mike / AA8IA - Email: my RR username @gmail
SDS100/BCD436HP/PSR500/PRO197/TRX-1/Airspy R2(x2)/Airspy HF+
  #163 (permalink)
Old 09-01-2013, 6:27 PM
Default MARCS site rebanding
Can also confirm Loveland (Miami Township) CC as 852.0625.
Dave Williams-N8DHW
Middletown, Ohio
  #164 (permalink)
Old 09-01-2013, 6:59 PM
mtindor's Avatar
OH/WV DB Admin
Thank you yet again, Dave. Much appreciated. The DB has been updated.
- Mike
  #165 (permalink)
Old 09-01-2013, 9:47 PM
Can confirm that Oxford's CC is now 853.0875.
Dave Williams-N8DHW
Middletown, Ohio
  #166 (permalink)
Old 09-01-2013, 9:55 PM
mtindor's Avatar
OH/WV DB Admin
You da man, Dave!
  #167 (permalink)
Old 09-01-2013, 9:58 PM
And not using any of the Trunker type programs either. Just using my Pro-106 analyzing the CC's.
Dave Williams-N8DHW
Middletown, Ohio
  #168 (permalink)
Old 09-01-2013, 10:03 PM
mtindor's Avatar
OH/WV DB Admin
Well, nothing wrong with making do with what you have. I suspect most people don't realize that they could do the same thing as you. I think either everyone believes they must run a trunking program to give us some updated info, or I've led them to believe that it's the only way they can do it rofl.
Anyway, thank you. That's very helpful.
  #169 (permalink)
Old 09-02-2013, 8:07 AM
The following sites are confirmed with unitrunker
Site 64 (Fremont) CC 853.850
PEERS:
Site 20 (Bucyrus) CC 853.350
Site 22 (Norwalk) CC 852.925
  #170 (permalink)
Old 09-02-2013, 8:29 AM
wa8pyr's Avatar
Technischer Guru
PEERS:
Got it, thanks.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
  #171 (permalink)
Old 09-03-2013, 4:47 AM
customseal's Avatar
with that info how do I add it so I can receive the OHP again? Thanks learning.
  #172 (permalink)
Old 09-03-2013, 9:57 AM
Bucko's Avatar
Newport Tower on now CC 853.0625 6F10h-0022..
  #173 (permalink)
Old 09-03-2013, 10:02 AM
mtindor's Avatar
OH/WV DB Admin
Thanks B. The DB has been updated.
- Mike
  #174 (permalink)
Old 09-03-2013, 11:17 AM
mtindor's Avatar
OH/WV DB Admin
Techs are working on the following today:
Little Hocking
North Bend
Carey was just declared rebanded.
Newport was reported rebanded by Bucko
I'm sure there are other sites being worked on today, but that's what I know so far.
  #175 (permalink)
Old 09-03-2013, 11:22 AM
mtindor's Avatar
OH/WV DB Admin
For viewers who are interested helping customseal (Steve) out:
1. He is in Fremont Ohio area
2. He has an HP-1
He needs some guidance getting his HP-1 updated. I don't own one or know how often the data gets updated in Sentinel for programming a scanner. Perhaps one of you HP-1 users can help him out.
mike
  #176 (permalink)
Old 09-03-2013, 11:43 AM
mtindor's Avatar
OH/WV DB Admin
6F16-054 North Bend rebanded per tech discussion with Helpdesk.
I really would appreciate it if somebody within the North Bend area could confirm the actual control channels in use for the site because (a) the freq in the PDF is not on the license listed in the PDF and (b) there was some descrepancy between the pre-existing 860 mhz control channels.
I've updated the DB to include all the likely control channels. But further clarificaiton by somebody who can (a) at least tell us the new primary control channel displayed on their scanner for 6F16-054 and (b) somebody who can run a trunking program on the rebanded site would be very helpful.
  #177 (permalink)
Old 09-03-2013, 12:17 PM
2. He has an HP-1
mike
The new Sentinel update was yesterday. It may or may not work
I have had to use the custom band plan in a favorite, but it seemed to work OK when I used the entire DB. It's hard for me to tell for sure though on the entire DB.
FWIW - updates are every Mon. baring unusual issues. If you have RR updated bu late Sun. or even early Mon. it will grab it.
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
  #178 (permalink)
Old 09-03-2013, 12:30 PM
mtindor's Avatar
OH/WV DB Admin
Thank you for that info. I guess it will be hit or miss as to whether Fremont will be listed with rebanded freqs then. Hopefully the person who needs help knows what to do with favorites. I've yet to get me one of those newfangled HP-1s. I wouldn't get one without the Extreme Upgrade, and I'm too cheap to get the bundle -- at least right now.
Take it easy,
  #179 (permalink)
Old 09-03-2013, 1:18 PM
mtindor's Avatar
OH/WV DB Admin
712D-29 Pleasant Valley should be rebanded. I'll make the changes shortly
M
  #180 (permalink)
Old 09-03-2013, 2:21 PM
Bucko's Avatar
Portland Tower on CC 853.3375 6F16h-0041..
