Thanks, all! Something actually changed in my scanner - still don't know what, but that's why I stopped hearing everything. Seems like the rebanding is going to hit the fan any day though.
Thanks for the update. I really didn't think Columbus would have been rebanded, for multiple reasons: (a) it's Saturday and (b) somebody would have already told us if it had been rebanded yesterday. But, ya never know.
At any rate, I'm glad to hear you got things straightened out now. Adjusting for the rebanding of 712D-001 won't be that difficult . Sure, all the frequencies will change and you'll need to modify your trunking tables, but you could do all of that ahead of time [by adding the appropriate likely new control channels and changing to the rebanded trunking tables]. If you did both of those ahead of time, you wouldn't miss a beat.
If I were monitoring 712D-001 regularly, I'd probably do this:
1. Add the following frequencies to the 712D-001 site [without removing any you currently have in]:
853.4875
853.3625
853.175
853.1125
2. Change to the rebanded trunking tables (at least the full tables that are publicized)
If I did that, I'd be pretty confident that I wouldn't miss a beat monitoring 712D-001 before, during or after rebanding. Once I knew rebanding had been completed, I'd then go back and remove the old 866+ frequencies.
Then again, you could just simply wait til you don't hear anything.
