Elyria PD
budevans
Cleveland, Ohio
The TRX-1 should automatically decode P25 audio (CAI). If you programmed your TRX-1 using the Whistler software check the DMODE setting for the frequencies in question. Typically the default "AUTO" setting should work.
To manually change the setting, click on the frequencies DMODE setting. Each mouse click will change the setting. There are three choices, Auto, Digital and Analog.
jdolina
Lorain Ohio
Try 155.1900 nac 293
I have caught some traffic and sounds like EPD once I vrify I will submit.
Also weird I can pickup on my radios but not with sdr# with dsd+ and the signal is strong.
radios4bill
N/E Ohio
Well I have searched the FCC Database and there has been some license mods done but still the same frequencies. I know that Cleveland Communications got the contract for the new system and they sell Harris radios and I am guessing are on P25 II ?
jdolina
Lorain Ohio
I will check tonight but I thought my 996xt was picking it up which does not do P25 II
I know the TRX-2 was loud and clear but very little traffic
Speaking of the modifications in the license I did see what looked like analog traffic on 155.9550 but did not catch it.
N8IAA
Fortunately, GA
That is because they are conventional and not trunk frequencies.
It is just P-25. No Phase I or II. I used to have a Pro-96 that received P-25 conventional without a problem. Any scanner from that era forward, will do the same, as long as it receives P-25 digital.
Larry
Chronic
Pretty sure the .1900 is just a temporary move until the dispatch console is rebuilt with the new system
jdolina
Lorain Ohio
The jail freq has not had any traffic as long as I can remember.
I do not see why they would go through the trouble of setting up the digital console to use .1900 and then switch. They have been using .1900 for the last few days as digital.
They do have .9950 which has not been approved as a mod to the license so it is possible down the road they switch?
OHIOSCAN
Lorain Cnty, OH
EPD receved a big grant recently for the conversion
Elyria upgrades its police dispatch center to digital - Chronicle-Telegram
Lorain agencies have also been up on MARCS testing
29501 thru 29525 have heard EPD detectives thru AVON Fire all testing on this block of TG.
29501 4790051 LORAIN COUNTY UNID
29501 4790037 LORAIN COUNTY UNID
29502 4790024 LORAIN COUNTY UNID
29502 4790042 LORAIN COUNTY UNID
29502 4790043 LORAIN COUNTY UNID
29502 4790044 LORAIN COUNTY UNID
29502 4790046 LORAIN COUNTY UNID
29503 4790038 LORAIN COUNTY UNID
29503 4790039 LORAIN COUNTY UNID
29504 4790141 LORAIN COUNTY UNID
29505 4790008 LORAIN COUNTY UNID
29505 4790047 LORAIN COUNTY UNID
29505 4790049 LORAIN COUNTY UNID
29507 4790121 LORAIN CO UNID
29507 4790122 LORAIN CO UNID
29507 4790123 LORAIN CO UNID
29507 4790124 LORAIN CO UNID
29508 4790010 LORAIN COUNTY UNID
29508 4790011 LORAIN COUNTY UNID
29508 4790013 LORAIN COUNTY UNID
29508 4790014 LORAIN COUNTY UNID
29508 4790017 LORAIN COUNTY UNID
29508 4790018 LORAIN COUNTY UNID
29508 4790022 LORAIN COUNTY UNID
29510 4790126 LORAIN CO UNID ENC '
29510 4790127 LORAIN CO UNID ENC
29510 4790128 LORAIN CO UNID ENC
29510 4790130 LORAIN CO UNID ENC
29510 4790131 LORAIN CO UNID ENC
29517 4790038 LORAIN COUNTY UNID
29517 4790039 LORAIN COUNTY UNID
29519 4790117 LORAIN COUNTY UNID
29519 4790119 LORAIN COUNTY UNID
29520 4790098 LORAIN COUNTY UNID
29525 4790039 LORAIN COUNTY UNID
parma,ohio
i put these in my G5 to monitor radio traffic on them see what happens
Chronic
EPD Dispatch has now been moved back to the repeater frequency 155.7300 P25
and 155.1900 P25 is being referred to as Channel 3
hdalgleish
I'm new to this whole scanner thing, and I don't know the proper scanner lingo. So I apoloize in advance. I have a quick question, and I'm hoping someone can help. I have an old uniden scanner that I used to be able to hear EPD. I can't get them anymore on the uniden scanner. I recently read that they switched to digital so I bought a Whistler WS1065 digital scanner. I can't find any Lorain County police stations using the WIN500 software. So now I am at a complete loss. Any help would be so much appreciated. Thank you
budevans
Cleveland, Ohio
Per the previous posts, Elyria PD is in the process of transitioning from Analog VHF to the MARCS-IP P25 system. I suggest that you use Win500 to create two Scan Lists.
One for the two VHF conventional freqs that Chronic posted. Leave the MOD setting at Auto and the Squelch setting at Search.
For the second download the MARCS-IP Elyria site from RR, including it's current Talk Groups. Once the MARCS-IP P25 Elyria site Scan List is setup, add the Talk Group Wild Card and Private Wild Card. The Wild Cards will allow you to hear all of the currently undocumented Talk Groups being used for testing.
Last but not least, keep an eye on the Ohio Forum to keep abreast of any changes or updates others report.
Hope this helps.
