Yes it is DMR Color 1 Slot 1 on 159.4350 MHz.thank you is it digital I take it?
Slot 2 is active with voice as well.Yes it is DMR Color 1 Slot 1 on 159.4350 MHz.
J
Sent from my Moto G (4) using Tapatalk
TGID 1 JailAll,
This DMR system has been added to the Crawford County listing. Please submit any talkgroups you locate.
TGID 1 Jail
TGID 2 Sheriff Dispatch.
All,
When attempting to download the system using Proscan the system type shows TRBO which is incorrect. Should be DMR one freq trunk.
That's how it's entered, as "conventional networked" which is equivalent to single frequency trunking.
If you can confirm that it's actually Connect Plus or similar I can change the entry.
Then this could be a Proscan issue with importing?
I only know if its not programmed as DMR single freq in my 436HP its silent.
