Davey1
What method do you use to program your scanner to listen to MARCS? Do you listen to just one site or multiple sites at the same time?
I have two Whistler scanners that I use for MARCS. One is the WS1040 and the other is the TRX-1.
I've found two ways to program the WS1040 that work well for me. I like to listen to multiple sites at the same time, so that I hear as much as possible. With the first method, using Win500 software, I set up one system that has all of the control channels for the (multiple) sites that I want to hear. I set the "Multi-site Mode" to stationery and check the box that says "Check All Control Channels in every Scan-mode pass." That way, when just listening to one trunked system I can hear multiple sites. The big disappointment here is that this method does not work on the TRX-1, because there is no "Stationery" setting available. This makes the TRX -1 much less versatile. The only setting available on the TRX-1 is equivalent to "Roam" on the WS1040. This is where for each system the scanner locks onto the best site and stays there. Therefore, to make this worthwhile you would have to be roaming over a large geographic area instead of at a fixed location and let the scanner lock onto the best site.
The second method I use with the WS1040 is to set up multiple systems and assign one site to each system. I have 5 or 6 systems set up to listen to at the same time. This works well and I'm successful doing it this way, too. I hear just as much. Although it shouldn't be, I have found this method to be limited with the TRX-1. If I try to listen to more than about 2 systems at the same time it seems to scan too slow and I miss too much traffic. So when using the TRX-1 I limit myself to one or two systems, which equals one or two sites.
Which method works best for you?
