I know there are at least a few people who use my OHP feed so thought I'd mention what I've done with it recently. Don't know if the listeners happen to be anyone who reads here or not, but oh well...
Been upgrading the home network, and generally moving things around, still have a bit to do so it may go down periodically in the next few days. Apologies for the interruptions!
But I'd be interested to know if it still sounds okay (or at least, no worse than before! ) as I have it on a new computer and soundcard. The card is the biggest worry, it's a cheap USB thing. I do notice some background noise that's always there, but it's fairly quiet so hopefully not too objectionable.
The computer is a new experience for me - an OpenRD Client, which is an ARM-based "embedded PC". I'm using it for a firewall box and hoping it handles the feed okay, seems to anyway. The thing pulls all of 7W while running so much lower power than running a regular computer. (For those interested, another option would be the Sheeva Plug, which uses the same processor. It doesn't have all the ports the Client does, but if you aren't running a firewall then no problem. Also costs less and uses 1-2W less power.) Sofware is Debian Linux, darkice for the feed.
One of these years I'll get around to reimplementing my tagging script and switch the scanner for one of my PRO-197s so I can have alpha-tags going as well... So much to do, so little time!
