Montco Fire Dispatching...
KB3SJV
Norristown Pa
I havent herd county drop tones on the 154.37 frequency for Norristown. they're only dispatching on the 800. Are they not using the Minitor channel anymore?
phillydjdan
I heard dispatches on it a couple of days ago. Either they are having technical problems, or they did away with it. Keep an ear on the 158.??? frequency for any station 27 dispatches. They may have moved over like everyone else is...
cdavisjr
Conshohocken, PA
As far as I know they still are for both 27 and 46 on 154.370 however without out of town assistance, every once in awhile I will hear 27 and 46 calls verbally said on 158.355 without tones and no special message, just their call. They are coincidenially the last 2 fire companies in the county minus Lower Merion to switch over which also to the best of my knowledge hasn't happened yet and I can't speak to the planning around them moving over. Hope that helps you
AGRadioNut47
Montco PA
Same thing with me i did not hear the tones on 154.3700 for a week i only here them on the 800 side of the dispatching i though there was something wrong with the that channel I hope they did not have a new freq.
cdavisjr
Conshohocken, PA
There are no new fcc licensed frequencies for either the county or the borough recently and have not heard 27 or 46 mentioned at all today on 158.355, I'm sure Norristown between the two of them is good for one call a day but heard neither. Anyone know of 27 or 46's current plans for switching channels?
phillydjdan
I heard 27 dispatched on a "standby at an accident" run about 5 minutes ago on their dispatch channel (154.370). Signal was very clear here in Northeast Philly.
AGRadioNut47
Montco PA
I heard 27 call too but i still did not heard there tones on 154.3700 just on the 800 side. I have it on my scanner program but i did not hear it for a week or two.I live in Montco to and i can not hear it. we just have to see.
KB7MIB
Peoria, AZ.
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
Is it possible that they changed their CTCSS/DCS recently? If they did, and you haven't changed it in your scanner, you won't hear anything. Just throwing an idea out there for you.
phillydjdan
My radio is programmed with the 136.5 PL, otherwise I pickup FDNY Brooklyn dispatch. Like I said, I clearly heard the call with tones on the frequency. I would suggest that you recheck your settings or antenna.
