BC355N Capable of scanning Dauphin County?
dmg1969
Newport, PA
Background. I used to live in Cumberland County which used VHF/UHF for many years. Scanning was my hobby until they switched to OpenSky. I sold most of my scanners except one (PRO-2014). I now live in Perry County and monitor PD/fire/EMS using my 2014.
I want to get a mobile and am looking at a BC355N. I want to also monitor Dauphin County because that's where I work. Is the 535N capable of scanning Dauphin County's system? I know NOTHING about trunking and talk groups as I never lived anywhere where I had to do it. If not, I will probably just stick with a cheaper scanner and monitor Perry County's VHF frequencies.
Thanks!
Dave
GTR8000
NY/NJ Database Guy
BEE00
As I told you in your other thread, no...the BC355N is not a trunking capable scanner.
Dauphin's system is digital, so you will need a digital scanner if you intend on listening to it.
markandjere
Franklin County, PA
You can monitor most Cumberland County fire and ems calls using one or all of the following EMS - 462.975 , FIRE - 46.06 is still used but a weaker signal so I use 460.575 to listen in to fire activity. As far as I know there is no way to listen to any PD traffic ............
bonk83
Union,SC
the bc355n will be good for vhf/uhf since it can narrowband it has also 800mhz it must be for analog i don't really know
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
How is 460.575 used? For what purpose?
dmg1969
Newport, PA
I don't monitor Cumberland's EMS, but I do hear bleedover from 46.06. It is one of the freqs used by Perry and I do hear dispatches for Cumberland. I can still recognize the voices of the dispatchers from when I did monitor Cumberland. I may have to put it in my home scanner and also the mobile when I get it.
