I don’t know about some of you but I will rearrange my setup until I find that perfect configuration. If you remember before I use to have the RH-96 remote head installed. I removed it for now and moved the HP-1 under the GPS. I found I wasn’t using the HP-1 as much as I wanted with 3 scanners in the truck. By removing the BCT-15/RH-96 I am now running the HP-1 full time. This also saves me from updating 3 scanners. I built several favorites listings for the HP-1 depending on where I’m at and when I leave town I let the HP-1 and the Garmin 18x handle all the rest.
