So, I guess you could call this my remote shack over IP. In the process of testing and running my new system. The setup is as follows:
Two BCD996T scanners
HP Pavillion Laptop
Bob's awesome program ProScan
Two $3.99 cheapo USB soundcards and two RS232 to USB dongles attached to a Belkin USB hub.
All this has been installed into a Pelican "suitcase", as it will end up being installed inside a shed at the top of a mountain. My very gracious father-in-law has some prime scanning property, and had already run up CAT-5 cabling and ac power lines to run a fridge and sound system in the shed at the top of a 600 foot high mountain ridge. The shed, aside from being waterproof, has no insulation, no heat or AC, and no forms of fan-based ventilation, so this should be interesting to see how it ends up working out.
For once in my life, if only because I don't have to look at it constantly, the install didn't need to be neat and clean, so its a bit of a rat's nest of wires in that box.
Will advise further when torture testing has been completed, and has been installed remotely.
HP Pavillion Laptop
