wuzafuzz
After several months I finally installed some toys in my 2010 Ford Fusion. With any luck I'll pick up a dedicated scanner soon. I'm thinking about the Home Patrol but haven't decided yet. Until then my PRO-106 will suffice.
The radio is a Yaesu FTM-350AR. The transceiver is mounted in the trunk, with the control head up front. I used CAT5 cable instead of the provided cable, so I had to dress that up with some split loom where the tan cable was visible. It looked nasty until I did that.
The control head is mounted with a Lido mount. That worked out quite well. It puts the control head in a great spot for easy viewing and handling. The gooseneck for the microphone has been used at various times for a GPS, phone carrier and now a home for the microphone. I might decide on a different option in the future. That depends on where I put a scanner.
For now I'm running a trunk lip mount for the antenna. I've always drilled holes in the past so this is my first go at a trunk lip mount. I don't care for it so far and may go ahead and drill a hole.
