Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 04-19-2014, 3:04 PM
Smile BCD536HP Install in my 2010 Ford Explorer
I've wanted a in-dash install in my vehicle for several years. It took me ungrading from a 996XT AND my vehicle for me to finally do it.
The Explorer uses a dual-din radio, so this made the task a lot easier, My installer said it was a very simple install and straight forward. The setup consists of a Kenwood Radio and a Uniden BCD536HP mounted as two single din radios replacing the factory dual-din. I used the Uniden BC23A amplified speaker mounted under the dash, power controlled by the switch. The 536 is wired to be hot all the time. I had it done this way to avoid some of the issues that I had been hearing about. If I'm going to be out of the vehicle for any period of time I will turn the radio off also, otherwise I just leave it on. With the speaker being wired to the switch, the sound cuts off when I turn the switch off.
I mounted the GPS on top of the radios, bur under the plastic of the dash. It still received fine and it completely hidden. The antenna is an inexpensive glass mount scanner antenna from Amazon and it is doing a great job receiving.
Old 04-19-2014, 3:19 PM
WatnNY's Avatar
Your installer did a great job!
Scanners: BC250D, BCD536HPx2, 996XTx2, 996P2, PRO-92
Ham: Icom 208H; Kenwood TM-V71; Hytera MD-380
Pro: Icom F5061; Kenwood 5210, 7180 & 8180; Motorola CDM1250, XPR4550x2, XPR6550, XTL2500
Old 04-19-2014, 3:25 PM
russellmaher's Avatar
That's a very nice install. You're very happy with it, I'm sure.
Thanks for sharing with us.
Russell
SEMPER PARATUS
BCD436HP HP-1 BCD396T BCT-7 BC350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050 TDXone TD-Q8A YAESU FTM3200DR FT70DR
Old 04-22-2014, 4:09 PM
Dann's Avatar
Very nice.
Scanning South West Washington And The Portland Metro Area
Old 04-22-2014, 4:52 PM
Kingmobileaudio's Avatar
I like it.
Sent from my SM-N900V using Tapatalk
Old 04-22-2014, 9:12 PM
popnokick's Avatar
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 7_1 like Mac OS X) AppleWebKit/537.51.2 (KHTML, like Gecko) Version/7.0 Mobile/11D167 Safari/9537.53)
Is your antenna a Tram 1199? I use one and they work fine IF you don't have metallized tinted glass. Can't beat for what you pay vs performance and simple install. BONUS: tilt down easily when in parking garages.
Old 04-23-2014, 2:49 PM
desert-cheetah's Avatar
Very nice!
Brenda
^--^ PRO-106...436hp...Home Patrol 2 ^--^
Old 04-23-2014, 3:34 PM
Thanks! I am very happy with it
Sent from my SCH-I545 using Tapatalk
Tags
536, install, mobile
HTML code is On
