Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 03-21-2018, 5:26 PM
737mech's Avatar
Default Gotta Have It! Scanner Setup
So not my original idea all credit goes to www.lazygranch.com but here's the perfect way to go out in the Nevada Desert with your Pro-2035 or 2042. The Ammo box is specific for PVS 14 Night Vision Goggles. The dimensions are perfect awesome. I'll use remote power and a cool Antenna for this setup. These boxes are hard to find on ebay and be careful on the sellers with a (1) rating I learned the hard way. Can't wait to go remote and try this!!
Old 03-21-2018, 5:31 PM
Radiosunshine's Avatar
k2ool/k1nng
Now connect an inverter and a 12 volt gel cell battery and a BNC antenna port on the top
Old 03-21-2018, 5:46 PM
737mech's Avatar
Default Plans
Planning on connecting a low band antenna NMOWB40B not to the case but near by on my truck or something.
Old 03-26-2018, 7:28 AM
I want to start doing that with some gear. A box with a battery, amped speaker and scanner for use in my work trucks.
Old 03-26-2018, 7:42 AM
have you been monitoring Red Flag?....that must be awesome
scanning the pinelands of south jersey bcd436hp pro651 pro652 pro2006 pro2096 bct15 grundig satellit 800
Old 03-26-2018, 2:36 PM
jaymatt1978's Avatar
One of my biggest mistakes was selling my Pro-2035
Old 03-29-2018, 8:13 AM
TailGator911's Avatar
Still kicking myself from last summer. Guy had 50-cal ammo boxes and 30-cal ammo boxes for sale - $12.50 apiece, buy 2 get one (30-cal) free. They were like new and I should have pulled the trigger then. I am hoping he is back at the Caesar's Creek Flea Market again this year. He was outside just to the right of the eastside main door.
What's the diff between the ammo canisters and the night vision goggle canister?
Very nice outfit you have there - I like it!
JD
kf4anc
SDS100, TRX-1, BCD536HP, WS-1065, BCT15X, BC895XLT, RS-2006, RS-2035, Misc. Others
ICOM R75, ICOM 746 PRO, YAESU FRG-7, YAESU 2800M, YAESU VX-7R, YAESU FT-2DR
SDR#
Old 03-29-2018, 9:54 AM
737mech's Avatar
Default Ammo box
The NVG case is taller than the 30mm box and usually still has the foam. Like I said the fit is perfect for pro2035 & pro2042.
Old 04-02-2018, 3:15 PM
737mech's Avatar
Default Almost ready to go out.
Remote Pro-2035/Ammo Case/ Larsen NMOWB40C/ Makita power supply repurposed. Testing today to see how long the battery lasts. So far just great it's 13.23 pm pst I started 08:00 pst.
Old 04-02-2018, 9:14 PM
It should last awhile. Scanners don’t draw much power.
Old 04-04-2018, 12:12 PM
wa8pyr's Avatar
Technischer Guru
Nevada desert, huh? Are you the guy they caught lurking around the fence near Groom Lake?
Nice setup, though. Ammo cans are wonderful things. . .
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
Old 04-04-2018, 12:28 PM
737mech's Avatar
Default Something like that
https://forums.radioreference.com/pi...ret-shack.html
Old 04-08-2018, 7:57 AM
Won't that setup get really hot without any vents of any kind?
Old 04-08-2018, 2:59 PM
737mech's Avatar
I will test it, I think the only real heat source is the power supply? So by bringing in 12Vdc thatís no longer a problem.
Old 04-08-2018, 8:25 PM
737mech's Avatar
Default Temp measure
Confirmed ok, I had it running on battery 12vdc for an hour with a temp meter probe into the ammo box along top of the scanner. Never got above 30' C/ 86 F so no worries.
Old 04-28-2018, 1:18 PM
k2ool/k1nng
I like your idea with the Mekita battery,very unique.The tiny voltage regulator on the radio shack probably doesn't get barely warm to the touch.
HTML code is On
