First Impressions
Let me preface this by staying away from the pricing and 'vaporware' issues. I treat myself to one extravagance a year and the Wouxun was it this go-around.
The Good:
This is the first Chinese radio that I could program by hand using the manual. Not like I had a choice, as there is no cable or software. But, decent documentation is the difference between programming ease and retreating from the thing in tears. The panel programming buttons are mirrored on the microphone, making things even easier. I blew through entering 25 odd repeaters in about an hour and a half after I figured out the menu hierarchy, with plenty of coffee and potty stops.
The manual is reasonably free of Chinglish and might have even been written by an English speaker. The diagrams of the menu are well laid out. Some of the menu descriptions are lacking detail, but become apparent once you start pushing buttons.
The display is thoughtfully laid out and reasonably sized. The ability to have channel numbers, frequency display or alphanumerics is a nice touch, especially if this ever gets Part 90 acceptance.
The receiver appears reasonably sensitive. I do not have any test equipment more complicated than a ham-grade wattmeter, so I'll leave the comprehensive testing to others. Again: first impressions.
Built in duplexer. I like that. Others might not.
Separate internal speakers for each receiver. More on that below.
Separation kit is in the box.
On air reports were good.
Very quiet cooling fan.
The Bad:
The manual states the the radio is Part 90 compliant. The box and the cover of the manual have an FCC logo on them. Of course, that's not happened. Amusingly, both the box and manual cover carry the Chinese patent numbers of the radio and the microphone with the admonishment that "imitation is not permitted".
Those separate speakers were from the lowest bidder. It doesn't bother me, as I've never had an amateur grade mobile rig with which I didn't have to use an external speaker. A couple of some R/S 19-318 speakers and some double faced auto trim tape solved the problem. After that, it filled the car with pleasant audio.
While we're on speakers, there is also a speaker in the back of the microphone. "Great idea" you say. Until you activate it. Perhaps my tin ears could not separate the distortion from the internal speakers. I'll be revisiting that as I shake this down further.
The Peculiar:
There may be an issue with slow response in the CTCSS receive. I need more operating time on it to quantify.
I'm not happy with the choices of backlighting for the display. You have white, blue and green, which are assignable to 'standby', receive and transmit. The green and blue are a bit dim for my tastes, and if there is a brightness adjustment, I couldn't find it.
RJ45 jack for PC programming and lashing two of these together as a full repeater. No programming cable or software, although both are referenced in the manual. The screenshots of the software look suspiciously like some Maxon LMR software that I've used.
Some of the features puzzle me. I can see FM broadcast reception in an handheld, but not in a mobile. Same with the 'scrambler' function: totally unusable on the ham bands and not robust enough for LMR if acceptance is gained. The 2.5 kHz step will need to be put in a type accepted version.
What the Hell is a Compand? Same with Noise Reduction? Again, I saw these features in the Maxon LMR equipment, which makes me believe that Wouxun might be a Maxon contract manufacturer.
I didn't play with the cross-band repeater function, as I've never seen the utility in it.
All in all, this appears to be a very nice radio IF it had the original announced 2.5kHz step, was Part 90 accepted and they put real speakers in it. The software and cable would be nice too, if only to facilitate fleet programming. I'll let others argue over the price point and let someone smarter than me put one on the spectrum analyzer.
73--
Tom KA9QPN
