I am attempting to run a stereo feed using RR ScannerCast on Windows 7. I have set up my broadcast station exactly as shown on the schematic at:
Setting up your Broadcasting Station - The RadioReference Wiki
When listening to the audio on the speakers of the broadcast computer, everything appears as desired: "Scanner #1" audio is only heard from the left speaker, and "Scanner #2" audio is only heard from the right speaker. The Peak Level Meter also confirms that the left and right channels are operating independently. However, when I listen to the feed on Broadcastify, the left speaker has audio from both "Scanner #1" and "Scanner #2". The right speaker is the same (audio is heard from both scanners).
I have selected "Stereo" under the Advanced Tab on ScannerCast. I am assuming that there must be another setting on the computer that needs to be adjusted.
Is anyone successfully running a stereo feed with RR ScannerCast on Windows 7? And if so, can you please let me know what corrections I need to make. Your assistance is greatly appreciated!
