BOB I would check both
Before this goes to far off topic, County Law has been and is currently patched to Interop 1 which is why it's showing as being in a patch. County Law 1 can be clearly heard on the County cell and been allowed on the County cell off and on since it was turned on. It's mostly allowed Monday-Friday with some exception.
Sent from my Nexus 6P using Tapatalk
Seems like Bethlehem EMS (154.3475) is being patched from time to time with TG 10925. It doesn't appear to be full time but the only P25 native traffic seems to be the ACSO Medic's. Guess it's being used as a method of interop.
Here is what I have identified so far:
10925 Bethlehem EMS 1
10927 Bethlehem Fire? (Not sure on exactly what the channel assignment is)
10933 Coeymans PD (Believe this is an encrypted TAC like the other County dispatched cities have)
10961 Guilderland PD
10967 Guilderland Fire
Also, anyone have luck identifying the following?
10024 Been a mystery here for a while, too.
10801 MUNI 1
13240 13241 & 242 are AFD DETAIL groups. Could be another AFD or a bad decode.
13805 I have tentatively identified this as belonging to DGS.
Sorry, I know that's a lot but they have had me stumped for a while.
Again, hope I'm not off topic, but I was holding out hope that the last couple towns discussed here would not convert to the County System. The reception here south of Albany is abysmal. Probably can hear about 1/5 of the transmissions clearly.
Unless you are saying I should just program the county cell and remove all others?
For those that have a G5v pager with Colonie & Albany programmed in it, how do you have your P25 Trunking System Site List programmed on page D2?
