error msg yaesu
hotsavannahs
San Antonio
Trying to set up my yaesu ft-65 for the gmrs frequencies.
Keep getting an error msg with ptt is pressed "Error beep, beep, beep"
Anyone have any recommendations?
cmjonesinc
It's TX band is only 430-450mhz as its an amateur radio. To use it on gmrs you'll need to modify it for out of band use. It's not like that from the factory because it's not FCC certified or legal for use on GMRS.
letarotor
Arlington, TX
Look up on YouTube how to unlock that Yaesu model and keep your fingers crossed that it will work with yours. There is a way to unlock some of the models but I couldn't tell you what the string of numbers are or the process. It worked on my friends but on mine it doesn't unlock it to be able to program in frequencies like the ones you're talking about. I'm bummed out I can't unlock mine.
Brian (COMMSCAN)
Sent from my SAMSUNG-SM-G930A using Tapatalk
cmjonesinc
Yeah the code thing seems to be hit or miss on the 65's. Something to do with the region I believe.
letarotor
Arlington, TX
It was my understanding that the European models would unlock but mine is an FT-65R/E on the box and I thought that that was a European model. But maybe it stands for something else? Either way, mine was a miss :)
Brian (COMMSCAN)
