Greetings...
I recently purchased a used BCD436hp and have had/used it for a month with no problems. I hadn't change any settings on the scanner. However, I used the ARC536 Pro to add a new favorite file yesterday and now the radio will skip channels every time the squelch is broken. In other words, if I'm holding on a PD Channel 1 and someone talks on the radio...the radio will change itself to channel 2. If someone were to talk on channel 2, the radio will automatically switch to channel 3. Its bizarre.
I did the old holding 'Department, 2 , 9' to set the radio to default and that seemed to work. However, when I used ARC536 Pro again the radio started doing the same thing. Is there a (Weird) setting I am missing? Otherwise, anyone with thoughts?
Tim
Tim
