needairtime
Well, I think it's not actually a Bipolar Junction Transistor but actually a SOT-223(?) SMT MOSFET as far as I can tell in the UV82 based on the assumption it's similar to the UV5R.
I was reading in the Baofeng UV82 manual that you must make sure that the antenna's SWR is no worse than 1.5:1 ...
... 1.5 : 1 ... WOAH. That's pretty strict!
Have anyone blown a baofeng final transistor?
Accidentally transmitted without an antenna? Time to get a new baofeng?
Loose antenna? Time to get a new baofeng?
Granted, buying another baofeng is probably cheaper than replacing the final...
(Incidentally my old Kenwood HT (which does use a BJT TO-5 final) seems to have survived a really bad antenna that I hacked up, I neglected the impedance matching needed. Still seems to work at least. The transistor seems to be rated higher in terms of voltage endurance unlike the MOSFET in the baofeng?)
