I've fine combed Internet and only reference to DFA are Nexedge Generation 2. So I will assume this system works as old Motorola, new Tetra and new DMR TierIII that it uses a base frequency and channel numbers are counted upwards from that frequency and the control channel only sends out channel numbers, no frequencies. And then the DSDPlus.frequency file are very much in use to display the correct frequencies in DSD+ that relates to the channel numbers.
Unidens DMR scanners only go by channel numbers that are programmed next to a frequency and that frequency are used by the scanner, whatever that frequency might be. To be able to program a Uniden scanner one have to correctly link a channel number, LCN, to a frequency and either need to use LCN finder or have the frequencyfile in DSD+ correctly setup to get any kind of helpful info from that program.
The channel numbers and frequencies found so far doesn't match.
/Ubbe
