XPR 7550e MDC1200 ID Sounds Different
chassed
CT
Hi just got some new XPR7550e radios and programmed the MDC1200 ID's into them and it has a diffrent sounding ID than Im use to. I was hoping to find a way to set it to the normal single chirp. Currently it has a series of very short chirps. Anyone have an idea if this can be changed in the programming?
firefive76
Kansas
Probably your preamble bit sync. I set ours to "0", otherwise you have a series of chirps before the actual MDC data is sent.
Preamble Bit Sync
Selects the number of synchronizing packet sent for the transmitting and receiving radios to synchronize prior to MDC signaling data transmission.
Range
Maximum
96
Minimum
Increment
N1GTL
CT
I'm not sure if you're referring to the TRANSMITTED sound or the sound emitted from the radio speaker. Others have covered the transmitted sound. If you're referring to the radio speaker, under the GENERAL settings, scroll down to "talk permit tone". You can disable the setting and it will eliminate the talk permit tone emitted from your speaker.
chassed
CT
Preamble Bit Sync
Range
Maximum
96
Minimum
Increment
This is exactly what it was. Was set at 6, now set at 1 and is much better! Thanks for the help.
chassed
CT
The other thing I have been trying to fix is getting the ID from the alias list to display longer. Currently it only displays the ID until the radio talking unkeys the radio. Any way to give it like a 20 sec hang time?
