I would delete that file out, and try these steps again:
BC125AT < UnidenMan4 < TWiki to download the driver. Please be sure that the scanner or theUSB cord is not connected to the computer until instructed to by the steps below.
1. download and open the zip file,
2. extract the BC125AT_USB_driver folder to an open area of your desktop, open it, and open either the XP or Win7 folder(depending on the OS of the computer you are doing this on)
3. open up MY COMPUTER(Win7 will list it just as COMPUTER) through your start menu
4. open your C: drive, then the Windows folder, and finally the INF folder
5. copy the file that you were looking at the end of step 2 and paste into the INF folder on your computer
6. run the BC125AT_SS programming software, turn on your scanner, and connect it up via the USB cord
7. If the computer does not automatically run through the installation, select on the TOOLS tab at the top of the programming software and select the COM PORT SETTING option
8. select on DEVICE MANAGER
9. right click on the model number of the scanner in the next window prompt under OTHER DEVICES and select UPDATE DRIVER
10. allow it to search automatically, it will find it, and start to install it for you
Once the installation is complete, you may go back to the COM PORT SETTING window and select AUTO DETECT and it should indicate that it was detected if it installed properly.
maybe the file is corrupted in some way.
