Sample audio can be found Here: ecidsf.com The fire Page is quiet, Whereas the Ambulance page is normal. These feeds are on Two different scanners, With two different Two Tone Detect's running. The Ambulance Scanner is plugged into the front of the host PC, And the Fire Scanner is plugged into the back, Audio is fine on the feed via Broadcastify, And when listening back on the PC Itself, I only have issues with TTD On the fire scanner recording quiet audio. Also, When listening to the Fire Feed VIA Scanner Radio (PRO) The audio is garbled.
