In my state I have the state patrol using p25 wiscom and all the local guys are running convent.
when I turn on the p25 it does not scan the other local stuff am I missing something??
any help would be great Im still pretty new to the sds200
Make sure that your conventional (non-trunked) frequencies are in conventional systems, not added to a trunked system. For the ones that you are
not hearing (conventional?), did you append those from the main database, or enter them manually? If entered manually, if you are using location, be sure that you also included the location information for them.
You might also attach your Favorites list (if you are using one instead of just the main database) to a post so that someone can see if something is incorrect or out of place. (Disregard the information below if you are only using the main database and location, not a Favorites list.)
Attaching an *.hpe file to a post
Use Sentinel to "read from scanner" if you have made changes on the scanner that were not also made in Sentinel.
Then, export the resulting Favorites list(s) into an *.hpe file. Then, attach that to a post and upload so that we can take a peek & see if anything is out of place. The Export function is listed under the File drop-down menu. If you have more than one list, export each Favorites list separately.
Note: To upload an *.hpe file, to the Forums, you must change the file extension to one acceptable per forum requirements. To do that, note where your exported *.hpe file is saved on your PC.
Using Windows Explorer, find the file.
There are two ways to do this. You can either change the file extension itself, or compress the file using
7-Zip or another file utility. The *.zip file extension can be attached to a post and uploaded to the Forums.
Or, using Windows Explorer, rename your file one of these two ways:
For illustration, let's call your exported file '
MyFile.hpe' (without the quotes).
<Right><Click> on the file & choose Rename from the pop-up menu.
You can then rename your file to
MyFile.txt, or
MyFile.hpe.txt in order to attach it to a post. Whoever views the file will need to reset the file name back to
MyFile.hpe, then it can be imported into Sentinel for viewing.
