Kenwood TK 5820-K programming error message.
RadioChief55
I have a Kenwood TK 5820-K that I have programmed quite a few times before. I downloaded the programming software KPD-112D version 2.01 and I get the following message. The firmware on the radio is 2.10.00 Any help would be appreciated. Thanks
The configuration data in the transceiver contains the configuration data for a function which cannot be read from the transceiver. To read the configuration data, the latest version of Field Programming Unit must be installed.
FARMER522
It sounds like you need the most up to date software version for the current version of firmware in the radio.
RadioChief55
Thats what it looks like. However this is the same software I always used, the radio has been in my truck since 2012. Never sent out for repair or firmware update. Weird.
Latest firmware for that radio is 2.21, released October 2017.
KPG-112DN latest version 2.33, released in Jan 2016.
The error message suggests that your software is too old. Did someone else program it at some point?
RadioChief55
I'm the only one who has done programming on this radio from day one. Thats what's so weird. I sent Kenwood an Email asking how I go about buying the latest software. I haven't heard anything back yet.
Contact your dealer. If you contacted Kenwood directly they likely won't be much help, if you are lucky, they'll forward it to a local dealer.
Wondering if something got corrupted in your software. Have you tried doing a rip-n-replace on the KPG software?
