needairtime
I'm having a large suspicion that I'm suffering a fairly large power penalty when using my LMRS radios in the 70cm ham band. Should I?
Both of my LMRS radios appear to have a factory frequency band of 450MHz-480MHz as they use the 13W Mitsubishi M57704H hybrid, though one uses it as a preamp and other as a final. How much transmitted power degradation can I expect to transmit at, say, 442MHz? 444MHz? Could it be half power? Worse?
My Icom mobile rig seems to be transmitting very little power, and seems to be easily overpowered by my Baofeng, at least from what I can tell from actually moving the radio farther away from the repeater. Not sure if it's due to the hybrid passband or perhaps it has some other issues like a blown final. Zero distance testing of my Kenwood has been done, which uses the same hybrid but as the final. Ιt has been in a fixed location since I got it working in the ham bands...
Any ideas, or pretty much people are using amateur-tuned equipment straight from the factory?
