Great replies. I guess that does bring up another question in my mind. How does tones coordination work? Is there any software for selecting combinations in an area that won't cause problems with others? My county had a several PSAPs over 10 years ago. So, there were a couple of "legacy" VHF fire channels as well as some other frequencies used for alerting.
Then, with a JPA (Joint Powers Agreement), they all came under one PSAP. A completely different set of VHF frequencies are now used for paging. One was a county repeater output and the other a PDs repeater output. It seems like one has all of the paging on it and the other carries fire traffic from the 800 MHz fire dispatch talkgroup(s).
I wasn't part of the planning for that changeover, but it was probably an opportune time for the fire departments to think long and hard about how they wanted tones used. I assume that if they were spending the time and money anyway to re-program pagers, they might just as well add any new ones at that time, if they needed them.
Since all of the fire departments are now paged out by one communications center, it is probably a bit easier to coordinate.
Now that "custom" tones are used, how far apart do they need to be from one another to be a "distinctively" different tone?
For example, these two pairs were logged when I wasn't monitoring:
2065.7 2070.0
2074.0 2070.0
Are they far enough apart to be two distinctively different tones or are they actually a Long Tone B that just happened to show two different frequencies in the log?
Another question, too. My fire department uses
979.9 1513.5
They do have some other tones, but this happens to be the pair that I hear used most frequently. Anyway, if a Long Tone B of 1513.5 is sent, would that "open up" a device with just the above? Or, if a Long Tone A of 979.9 is sent, would that "open up" that same receiver? I should point out that I don't know if that is what they are doing yet, I am still logging the tones being received. I think at least some of the departments are being paged out and the computer voice announces All Call and the all call tones seem to be completely different from either the A or B tones in that department. But some do seem to have a tone in common with the various stations, so I guess it just depends.
