I am trying to complete a project with my BCT15X and an Arduino.
I have everything done except cannot get a peep from the scanner. So I have a few questions, and am wondering if someone could help me on this one.
First .. what pins are used on the BACK of the scanner for remote communication ? I believe it may be pin 2 for receive on the scanner and pin 3 for transmit from the scanner. Also, do I need to use a RS232 to TTL device ?
I have not been able to get a peep back from the scanner when I send a command .. ie GLG. That is the only command I need to use .. as I just want the channel data.
I can connect to the scanner on the back using a DB9 null modem cable and use virtual control (ARC-XT Pro) or RC-Control and have it work.
Kevin
Kevin
